(quoted from post at 17:03:13 09/11/11) This what I found I removed the countershaft bearing support to find that the bolt that holds the pto hub gear on has broke and would not let the pto engage drilled and tap the countershift and put a new washer and bolt back in countershift would not come out do to the snap ring in front of the gear and front bearing would have to split the tractor at the motor and tranny to get to that put the pump back in and she goes in pto now i can look at my hydraulic they will go up but won't lift so going back in to look for leaks will let you know what i find thats soundguy for your help I did go get a fo4 manual made more sence when you can see the pics and see the words thanks again
