without rare aftermarket devices, PTO is not live - meaning when you push in the clutch, the PTO stops turning.
Advice - install an ORC on the PTO shaft
if the pto is turning now,you probaly have the lever on the left side undrtheseat low on the trans engaged,, I would think the wobble could be a bent shaft if not then a bearing more tan likely
Explain vibration?
If you have an ORC installed.. it may wabble a bit.. the more wear.. the more wabble.
If no ORC installed and the pto has up/down or side/side play.. then a bearing is going.
also.. non-live, as the other posters said.
soundguy
