pulled threads on block
warren (il.)
hi i was putting head on my wd45. torque to 45lbs. and the threads strip out of the block. now what do i do? WILL A HELI COIL WORK OR MAYBE JB WELD AND A STUD. I DID TAP THE HOLE AS FAR AS I COULD AND USED ALONGER BOLT BUT I GUESS THAT WAS NOT THE ANSWER. ANY IDEAS THANKS
The Heli-Coil is a good repair, but you need the drill bit they supply in there deluxe kit and also the hole must be drilled as straight as possible. If you have not already done this you need to run a bottom tap into each hole in the block and clean them out with compressed air. You also need to lubricate the threads ( very sparingly ) with a light oil or you can creat what is called hydraulic lock when the bolt goes into the block. this can crack the block.
