1968 Ford 4000 3 cyl diesel independent PTO.
Is there anything bolted to the lower cover that has to be unbolted from the inside?
I have previously moved the tube going to the flow control valve and removed all bolts. The cover is stuck tight. Even tapping it like you would to remove a stuck valve cover wouldn’t release it.
What else needs to be done to get it off?
Lower cover in the picture.
