Question.............
Goose
I have an idea for a simple, cheap log splitter. My H Farmall has a bucket loader on it with a hydraulic tilt bucket, ergo, a two way cylinder to tilt the bucket.
My idea is to build a splitter that would be on an axle with wheels on one end, and attach to the bucket on the loader by maybe a trailer ball hitch. Then simply have couplers to uncouple the hydraulic lines from the bucket cylinder and couple them to the splitter cylinder. There's a dual lever control for the loader mounted on the light bracket to the right of the steering wheel with a single acting lever to raise and lower the loader, and a two way lever to tilt and untilt the bucket. I'd run a rod back to operate the two way lever from in front by the splitter.
My question is, would the stock H hydraulic system with the belly mount pump handle this with enough pressure to operate the splitter?
mostly depends on what kind of wood you are splitting.however,the basic answer is the H doesnt make enough pressure
If I might ask, Gene, where are you located? My first name is Gene and my mother's maiden name was Bender. Her parents and other kinfolk originally settled around Ft. Wayne, Indiana before migrating to eastern Nebraska.
Been doing just that with the hydraulics on my JD A for over 30 years. Used a 4" diameter cylinder. JD system puts out just over 1000 psi. I find one or two pieces a year I can't split. I cut everything from oak to elm.
Paul
