Bspauld
If you have a 12 volt coil that says you need a ballast resister is it actually a 12 volt coil? or is it a 6 volt coil and needs a ballast resister??
If it says you need a ballast resistor its a 12 volt coil. You can buy a 12 volt coil from Napa that has a builtin ballast resistor for about $18.00 Part No. IC14SB. Hal
Could be either and might depend on what tractor it is for as well. If it is a square can coil for a Ford N look in the archives over on the N board for many discussions on this topic.
I'll ad that the rating is just a generalization. If it says 12v and indicates the need for a ballast resistor, it will probably work OK on 6v without a resistor. That is not to say it is a 6v unit, it is just within the range of primary winding resistance that works on 12 w/resistor, or 6 W/O. There are 6v coils for use with ballast resistors!!! they will not work W/O resistor on 6V, and will not work on 12v Without overheating, Jim
"If it says you need a ballast resistor its a 12 volt coil."
What the HELL does THAT mean???
"You can buy a 12 volt coil from Napa that has a builtin ballast resistor"
ACTUALLY, the coil is simply wound with more wire in the primary so NO ballast resistor is needed, internal, external, or otherwise.
I bought the coil from NAPA 2 years ago,I told them it was a 6 volt system and thats the coil they gave me,I have seen several 12 volts that said a resister is needed. I was just wondering if there are 3 types of coils. A true 12,and 6 volt and a 12 volt that needs a resister.
