questions for d slater/ leaking TA
Anonymous-0
got the hoods ,hydrolic lines ,gas tank ,and hydro
tank/valve bank .off the 350.ready to remove belt
pulley and ta cover.do you think add some deisel
fuel to the tranny to help find witch seal is
leaking?i quess my next step is to build some
splitting stands.
Oil level is below the seals. Except there's a pocket where the t/a is located that traps oil maybe high enough to leak out the carrier seal to t/a clutch compartment when not running. Others won't have much oil to them unless running or tractor tilted out of level on hills.
Probably can see what side the oil comes from after the top plate on the center housing is removed. Unless its leaked bad enough to saturate everything.
Probably my last time looking at the computer today if any other questions someone will know the answer.
