I take mine apart & install new bushings. The vertical rod is pulled out, hole drilled oversize about 1/2" down, & a bush is pressed in (can't remember the bushing size right now). I also had to shorten the rod to carb a little to take out slack. Seems to me like the shaft may be shimmed, but that is done when it is taken apart. Sounds like it is really worn. My UTU would throttle up but would fall flat on it's face when it started to get under a load. Did the above & it works great now. I have also rebuilt my two Z governors & they work great. Hope this is some help!
