Radiator Mounting Stud for Farmall H
Murray M
I am trying to locate two radiator mounting studs for a 1945 Farmall H. The short story is that I couldn't move the nuts at the bottom and I cut them off. It was then I realized that they thread into the radiator. Case IH doesn't have them and I can't find a coarse thread 7/16th bolt long enough to make one. Any ideas?
Try NAPA. They have access to a wide variety of studs and likely can get you some that will work.
Threaded rod works perfectly fine,I used it on my H I had,and on the M I have now.Make your own,make up your own springs as well.
