RD450 transplant
I used a 560 because of the bigger bell housing so I can use a bigger clutch. There is not much difference in weight if you strip them down but a little how much I'm not sure. If you search RD in a 560 on here you can get all the info you need for the swap.
I would go with the 560. Heavier rear, bigger clutch.
did you make your own side shields? and where did you get you scatter blanket? You have a very nice clean looking tractor.
