Re: Power Steering
Steve@Advance
Diagnosing hydraulics is sometimes a difficult and involved process.
First, take a look inside the pump reservoir (if the cap is on the reservoir), you should see oil swirling around. When there is no demand for steering, the oil freeflows from the pump, through the directional valve, and back through the return line.
If there is no movement, the pump is not pumping.
To properly test the pressure you need a gauge. Or you can cheat a little bit.
First, set the throttle above idle. With the weight on the front wheels, turn the steering wheel enough to shift the directional valve. Watch the hoses, listen to the pump and engine. On a normal working system, you will see the pressure lines jump, hear the pump load, and the engine labor.
If there is no change at all (and there probably won't be), the pump is not making pressure or the fluid is still freeflowing.
Next test, and I'm saying to do this at your own discretion as there is a level of danger of damage (wear safety glasses and a welding glove), identify the pressure line (be sure you have the pressure line, not the return line!). Cover the line with a shop rag, carefully crimp the line shut with vise grips. You should hear the pump load heavily, the engine labor, if belt driven the belt may slip.
If none of this happens, the pump is not building pressure.
If the pump loads, the pump is working, the problem is in the valve or cylinder.
Is the cylinder made on the directional valve, or are they separate, connected with hyd hoses?
If it's all one piece, probably best to just exchange it for a rebuilt assembly.
If separate, try this:
Disconnect the hoses from the valve, find the correct fittings to plug the valve where the hoses were removed. Be sure to use the proper plugs so the threads are not damaged.
Start the engine, turn the steering wheel. The engine and pump should load. If not, the directional valve has a problem, maybe repairable, maybe not.
If the pump loads, plug the ports on the cylinder. Try to turn the steering wheel. If the wheel turns, the cylinder is leaking internally. Some are repairable, some are welded. The welded ones are usually just replaced, but they can be cut open on a lathe and repaired, welded back.
Hope this helps, let us know...
