rear axle bearing
Anonymous-0
i am trying to get the bearing on the axle r side. So far no luck. i am hammering the axle from the outside because i believe the axle is one piece with the brake plate. i find too much resistance and dont want to break the whole thing. if i hammer (the axle) rfrom the inside out, i cant either. the bearing is stuck reason for which i want to change it. any suggestions?
Not clear on what axle you have. Assuming it is from a rearwheel drive car or light truck, the ones I have dealt with were pressed on and were removed by taking it to an auto parts store where they used a hydraulic press to press the old bearing off and press a new one on.
KEH
Hello KEH, thanks for your quick response. I apologize, i did not include what rear axle. It is from a super a farmall tractor year 49. if you can help, i will appreciate it.
heres a page from the i &t book maybe it will help.
<a href="http://photobucket.com" target="_blank">
axleremoval.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket
</a>
Untitled URL Link
dear glenster, thanks for your help. using the diagram, i tried to bump the differential axle in and out and cant get to be released. i am not sure if the bearing is stuck to the shaft. bearing is not stuck to the housing i wonder if heat may help unstuck it from the bearing. i bumped it hard but not to the point of breaking the housing. any suggestion? thanks
