ed cummins
Hello All,
1963 Ford 4000.
So after replacing all the bearings on the rear end and adjusting the axle spacing shims correctly there is still a knocking sound coming from the rear axles left and right sides when you shake the tractor back and forth. The harder you shake the louder the noise gets. It was there before I replaced the rear axle bearings. The differential is not moving back and forth when I shake the tractor.
Is it possible that I need to remove a axle shim or two and get the bearings a little tighter? The lugs are tight and the weights are tight. I just cant figure this out.
Any input would be helpful. Thanks Ed
1963 Ford 4000.
