rear axle seal tool
kano
Greeting to all,
Trying to install rear axle seals in mf 265. In the Philippines and find myself in a bind. Only tool to pull plantary from axle shaft is in manila(one Hour flight north)and not available. Can someone give a description,measurements,photo?so can manufacture same here at machine shop? Know Odds are bad but can only ask. Thank you in advance for any input. Suggestions welcome.
Have a great day.
Joe
([email protected])
I don't know if it is comparable, but I made a device to separate the outer axle stub from the planetary carrier on my MF Super 90. I purchased a piece of steel 1" thk. x 12" sq and drilled holes to match the carrier. I used (3) stud bolts, with nuts, I believe they were 1 1/4" dia and used a 50 ton hydraulic cylinder. To make this all manageable, I drilled and tapped a 1/2" hole into the center of the plate and installed an eye bolt, then suspended all from an engine hoist.
Thank you for your response. Gives me a direction and This was what I was looking for. Nice to see a can do attitude.
Joe
