Rear tires sizes
Ron Tron
I have old 13-24 tires on the rear of one of my 9N's. They are shot and I blew the tube putting air in one of them. Is there a smaller tire I can put on. the 13-24 is really fat and I was hoping to get something like the 11.2-28's that are on my other 9N
I agree with Old, 24 inch tires on a 9N would be very unusual. It would even be
difficult to put wheels or rims on it from another tractor model given the unique hub
pattern of the 9N/2N.
If you indeed have 13-24 tires on your 9N, then you will need to replace the entire wheel assembly with one from another 9N to get to 11.2x28.
The wheel centers would have to be cut down and welded into a 24" rim. It's not practical to go back the other way unless you use parts off another 9N.
Now are you sure you have a 9N? If it was an 8N, I think it would be rather trivial to mount a set of old combine tires on there, which would explain why it ended up with 24" rims.
(quoted from post at 03:57:06 10/16/20) If you indeed have 13-24 tires on your 9N, then you will need to replace the entire wheel assembly with one from another 9N to get to 11.2x28.
I wish it was easier to post pictures here. It's time yesterdaystractor to upgrade there software. LOL
That being said its a 9N .....It looks exactly like my 39 9N that I have had for 20 years. I bought this one from Kelly Johnson's step son who told me it was owned by Johnson and used it on his ranch near the Reagan ranch in Los Olivos. Kelly Johnson was the guy who started skunkworks and developed the SR71 so I have painted it black and silver and call it the Blackbird. Anyway I just measured the bolt pattern on both of them and they are the same. 7 3/4" from bolt to bolt and 15 1/2 " across. but the Blackbird rims are 24 inches and the old gray is 28 inches...........any help?
If you switch out to 28 inch rims you will also need to 28 inch centers. I have the 28 inch centers but no rims. I also have 32 inch centers and rim but the rims need work and I have 32 inch tires
here are the two different tires and rims
There is nothing difficult at all about uploading pictures on classic view. Just
scroll down to "Choose Files", select your pics from your file and click on it. Repeat
for more pictures. Hit the "Preview" icon and if you are happy, then hit the "Submit"
icon. Easy and simple. If you want to edit/modify your work or add more pics with
added dialog, hit the "Return to Forum" icon and repeat the process, and then when
finished, hit the "Submit" icon.
Yup ive got a 2N with 24's it happens.. you could modify the factory centers then weld them in.. kinda kills the option of adjusting track width.. but the 24 tires had the same overall DIA but much wider to give better flotation.. 13-24 was a very common size on older construction equipment..
(quoted from post at 13:25:24 10/15/20) I have old 13-24 tires on the rear of one of my 9N's. They are shot and I blew the tube putting air in one of them. Is there a smaller tire I can put on. the 13-24 is really fat and I was hoping to get something like the 11.2-28's that are on my other 9N
I'm thinking taking the rear tires off the tractor myself and taking them in to be mounted with tires I can buy online.
I would appreciate folks sharing their experiences on how they changed their back tires.
If you have the correct tools and the know how not all that hard to do but with out the correct tools and the knowledge of how it can be very hard and even deadly.
But me I worked at a tire shop for a while so I have the knowledge and the know how and the correct tools
Tires can be changed on a wheel without removing the wheel from the tractor. If you have a way of breaking a stubborn bead, it can save battling rusted / stuck bolts.
Some beads are stuck so hard that for me, it requires taking the wheel off.
Tire shops will dismount / mount new tires and tubes, on or off the tractor. That being said they do this for a nominal fee when purchasing tires from them. You may find increased fees for dismounting and mounting if you bring your own tires. May defeat any savings on the rubber itself.
oNE OTHER QUESTION........I have a tire shop about a mile away over a freeway overpass. I was thinking of driving it there with the blown tire. A back hoe operator neighbor of mine says it will never make it. I disagree if I drive slow. Any comments?
