Rear weights info
Tom in Mo.
Anyone know of a information resource that would detail dimensions and specs of rear cast weights? I now use Massey Harris rear weights on my JD 1020 as they fit nicely. Specifically, I'm looking for what I could use on the rear for a M-series Kubota.
Cub style I-H rear weights are very close to fitting but the center diameter is a half inch too tight. I have hundred series Case weights and 10 series JD weights that are too big a diameter.
I know I can order them from a dealer but that's too easy and I'm a cheapskate. Any thoughts?
Make a template with the bolt pattern, center hole diameter, and
outside diameter , and valve slot, if it needs it. Make the template
OD as big as you can get to fit against the rim. then take with you
and visit dealers and junkyards. I have IH 140 wheel weights
hanging on my L2202 kubota. Had to use 7/16 mounting bolts,
instead of 1/2", LOL.
