Hi Folks,
I just got my rebuilt 1971 Ford 201 cid 3 cyl diesel engine back from the machine shop. I went to install it and noticed that the rear cover plate between the engine and flywheel is sticking out about a 1/4" from the engine at the bottom and is touching the lower portion of the flywheel.
I tried to look between the gap up towards the crankshaft to see what was preventing the cover from sitting flush on the engine. I think it might be the gasket at the end of the crankshaft between the engine and cover.
If it is a gasket should the gasket be sticking out enough to prevent the cover from sitting flush against the engine?
The top part of the cover seems to be ok, but there are 3 bolts (1 above and 1 on each side of the crankshaft) holding the cover securely in place. There are no other bolts holding the cover on. I assume it might be ok once the engine is bolted to the transmission, but I would hate to have to remove the engine again once it is reinstalled.
Has anyone seen this issue before or have any recommendations? I plan on calling the machine shop to ask them what they think, but I am not sure how much experience they have with this type of engine.
Thanks,
Ray
Thanks,
Ray
