Then you got lucky, I had a Ford CAV DPA PUMP last week that had the same hard starting when hot trouble, and a Stanadyne/ROOSA JD 4020 pump this week that both need the head/rotor assembly replaced. Poor fuel filter care can wear the rotor and head bore quickly causing the internal leakage. The vane pumps are designed to move much more fuel through the pump for lubrication and cooling than the engine actually needs to run.My experience has been different. But I do not have any financial gain involved.
I really don't think you're going to do much better than that.... the last head assembly i bought was about $700 , and that was a decade ago.The injector pump is on an Oliver 88 with a super 77 engine. The injector pump is a roosa master 635
I called a local Oliver parts dealer that I do a lot of business with and he said he has a completely rebuilt roosa master 633 for $1000 or $800 if I give him the core. Does this sound reasonable?
Send pump to a professionally trained FUEL pump specialist:Hello all I have a roosa master Injector pump that has pressure issues. I can't start the tractor without pull starting it and I can't bring the engine to an idle without it dieing. So I want to rebuild it but all the shops around me either don't want to mess with it or they want a high rate to work on it. So I thought I could rebuild it myself. the mechanical part does not worry me. But I'm not sure what all goes into recalibrating the pump.
Do you guys have any input? Thanks
Of course you have seen bad pumps. But if they all needed heads and rotor there would be no core pumps to rebuild. The rotary pumps are simple robust pumps that mostly need simple repairs.Then you got lucky, I had a Ford CAV DPA PUMP last week that had the same hard starting when hot trouble, and a Stanadyne/ROOSA JD 4020 pump this week that both need the head/rotor assembly replaced. Poor fuel filter care can wear the rotor and head bore quickly causing the internal leakage. The vane pumps are designed to move much more fuel through the pump for lubrication and cooling than the engine actually needs to run.
They can do whatever they want with it, no skin off my nose. You would be surprised how many I see on occasion that come in after, "I've had it apart three times and it STILL won't work!Of course you have seen bad pumps. But if they all needed heads and rotor there would be no core pumps to rebuild. The rotary pumps are simple robust pumps that mostly need simple repairs.
Why do you not want people to fix any problem with there pump?
A. M. you can contact Dieseltech through the YT private message system called “Conversations” by the software. To do this click his username by his reply and there you will see “Start Conversation” click that and it has a form that looks very similar to how it did when you created this post. Fill that in, this will be private message between him and you. When he replies a number will show up by your envelope/mail symbol. You click the envelope to see the “conversation”/message and then reply to him there again in private. Do not check “Lock Conversation” that will shut off anybody’s ability to reply. That is just a hard stop if it is ever needed.Reach out to diesel tech on here before you do anything.
The problem lies in the word "mostly".Of course you have seen bad pumps. But if they all needed heads and rotor there would be no core pumps to rebuild. The rotary pumps are simple robust pumps that mostly need simple repairs.
He moved to Michigan from New York some time back. Reason I don't encourage it is because I've seen too many times Billy Joe Jim Bob Bubba Junior makes the damage much worse after he "attempted" to fix it..Twenty or so years ago there was a poster on this forum that went by "JDMaris". He had been a Deere mechanic. He encouraged people to work on their own injection pumps. He said most of the pump problems could be fixed on the tailgate of your truck.
In the past this forum has helped and encouraged people to fix their own tractors. I spent some time away from this forum and on my return I find people advocating you can not do that yourself. This change makes me sad. I really enjoyed the old days of help and encouragement.
Yeah, not to mention busier than a one-legged man at an a$$-kicking contest...You have a competent Injector pump Tech right here on Y T, Dieseltech. Reasonable and honest.![]()
Yes!The injector pump is on an Oliver 88 with a super 77 engine. The injector pump is a roosa master 635
The DGFCL635-7AQ pump you have IS NOT for the Oliver/Waukesha engine you have, it's for a much larger Continental TD427 turbocharged Genset engine. You should look for one of these following pumps.The injector pump is on an Oliver 88 with a super 77 engine. The injector pump is a roosa master 635
J.DeMaris was originally from Northeast VT, then he lived in upstate NY near Tug Hill for most of the time that he was posting here. He is a very good mechanic. I remember his post about repairing them on the tailgate of a truck, and yes this still applies. Perhaps the difference is in the number of posters here who had tried repairing pumps themselves with a lack of success. I would estimate that for everyone who posts about repairing one successfully, there are twenty who post because they tried and were unable to solve the problem. A lot of this is due to the lack of a test stand which you need for adjusting the pump for proper performance one it is back together with some new parts.Twenty or so years ago there was a poster on this forum that went by "JDMaris". He had been a Deere mechanic. He encouraged people to work on their own injection pumps. He said most of the pump problems could be fixed on the tailgate of your truck.
