rebuilding Dearborn frontend loader rams
Anonymous-0
Where in the K.C. MO metro area can I go to find the seals/gaskets, o-rings or a kit to rebuild my rams for my Dearborn loader?
In your area if you look in the yellow pages you should find a hyds shop and they can rebuild them easier then you can and probably cost you less if you do it that way then if you try. I know for sure in springfield theres a shop and also in lebanon since I have used both of them in the past and found it saved me $$ letting them do it plus if done wrong you can always take them back and say whats up with this but if you do them you can only blame your self and they are easy to mess up if you do just a little bit wrong on one BTDT
Hobby farm
Old's right on. I had an old ford hyd cyl from a 711 loader rebuilt a few weeks ago.. My local hyd shop did the job in less than 2 hours and it used all 'on-the-shelf' parts for which i was amazed.
Soundguy
Just go to TSC or any local ag store and get a universal seal kit for your diameter ram. $10-20, Use the seals that closly match your old ones. Hydraulic shop will do it but they usually get the big $$ for parts and labor.
