rebuilding JD loader cylinder
matt e
I have a boom cylinder off a small crawler loader I've been trying to rebuild. I've done many of these in the past and never had a problem.
I can't get the rod guide to break loose... I made a spanner wrench that fits in the four little slots and had an eight foot pipe and can't get it to break loose. Tried penetrating oil for a week and heat. I don't want to get it red hot, but maybe that's what it is going to take.
Now I've got the slots so screwed up it wont hold a wrench anymore, so I'm going to have to weld something right to the rod guide to try again.
And Yes, I removed the set screw.
Does anyone have any suggestions, or good thoughts??? prayers wouldn't hurt either.
WE JUST WENT THROUGH THIS ON A 644B AND I KNOW WHAT YOU ARE GOING THROUGH. WE USED A 4' PIPE WRENCH AND A CHEATER TO FINALLY GET IT OFF.WE HOOKED A CHAIN TO THE PIPE WRENCH AND ATTACHED IT TO ANOTHER LOADER TRACTOR TO BREAK IT LOOSE. GOOD LUCK!!
Don't be afraid to put the heat to it. Get it dark red around the outside of the tube then quench with water. Don't worry you won't hurt it. It may take more than one heating. DO NOT turn rod guide while hot. Heat softens the metal and will result in the threads galling. Once heated, quenched and cooled to the touch use penetrating oil for lubrication.
Isn't there a danger of the cylinder getting too brittle when water quenching? Do I need to heat it up to reanneal it after the rod guide breaks loose?
I don't know what type of steel the tube is made out of... Mild steel not a big problem, but if it is some type of medium to high carbon that could pose a significant issue.
Not doubting, just checking...
Most cylinders are made from high grade seamless tubing. I would say it's low carbon steel since it is under a lot of pressure and the hose connections are welded to it. I don't know about quenching it after heating it though. If you have to weld something to the end cap, that might be enough heat to get it to loosen. If not, I'd try heating it and letting it cool on it's own or use an air nozzle to speed cooling. Maybe a damp rag could be blotted on it after heating but pouring water on it while red hot will weaken it. You could always ask a JD dealer how they loosen them. Dave
Finally got the cylinder apart tonage was not the answer. On closer examination if found six little punch marks around the tube at the rod end. These are on all the cylinders on this crawler. was this a factory thing? Tried PD's suggestion a half dozen times to no avail. Finally drilled out at all of the punch marks as a last resort thinking maybe they were marking plug welds. (they weren't) With a small 2' bar I had some pressure on it and just touched it with the torch by accident. Wouldn't you know it moved. Turns out it wouldn't turn cold no matter how much force. Same thing if it got too hot. Had to be just the right temp and it backed right out.
now I have to figure out how to plug my "frustration holes" in the tube.....
Thanks for the suggestions
Are the holes you drilled where the tube is threaded? Welding them up is probably the only fix. The threads will probably have to be rethreaded as well and the tube checked for proper size. Dave
Yep, they are in the threads. It's not a sealing area, so as long as I can keep the water out It should be ok as is. Thoughts??
I could weld it up then chuck it up and re thread it, but I don't think I'm getting much bang for my buck so to speak b/c it's going to take a lot of time to relocate on the exsisting threads.
Again I want to get some opinions on this so let me know what you think.
Matt
Right now the plan is to fill the holes just shy of the threads with JB Weld. I'm sure I could weld it or braze it from the inside of the tube with a copper block on the outside again just shy of the depth of the threads and make a more permanent repair, but I'm not sure it's necessary.
Looking back I can't believe I drilled holes it it, but when you have ten feet of pipe and it's still not moving you get desperate.
Could you weld the holes from the outside being careful not to get enough penetration to damage the threads? I'm sure you could get a tiny zip wheel for a die grinder to clean up the threads if you needed to. Dave
