Recommendations Please
Samaritan 01
I own a 1950 Ford 8N and I'm looking for a plow or disc. I live in northeast Colorado (Plains) and I will be dry land farming crops such as wheat and alfalfa in sections less than 20 acres.
I need some suggestions; one or two bottom plow?? Disc? Specifically what size, make, year?
Thanks for the assistance guys.
2-14 will probably be the best for your area. Ya you might do ok with a 2-16 but that might be pushing it a bit. A 2-12 would work very well and you would not be lacking for power and still do a good job
Hope you are not planning on getting a lot plowed in a day.....LOL, it took me a little over 11 hours to plow 7 acres of sandy loam with my 8N and 2-14 plow. And the hay part may not be a lot of fun. While the N can run a small square baler I wouldn't count on pulling a wagon behind the baler.
Rick
2 bottom plow.. 12 or 14.. 14 probably more productive.
6.5 dual ganged 3pt disc.. or 8' pull type.
soundguy
Hard to say without knowing what type of soil you have ,but if its like mine in western okla heres what i use.I use a HEAVY drag type disc,CASE no idea of what model 8 ft.and i use a dearborn two bottom disc plow,model 10-80.My land is a mix of really hard clay,shale and sandy loam.I use the disc plow because it breaks the soil up pretty fine as your plowing instead of leaving it in large clods,and i use the disc to level.My grandad who farmed the same place had one piece of equipment,a one way about ten ft,but he had a bigger tractor.But their was several built for these tractors that were as i recall 4 ft.They work very good if you have any way decent or sandy soil .And they are a real time saver ,as you can lots of times put your wheat ground in a good shape to plant with one pass.Several people made them,Taylor made a good one as did ferguson i think.Saw a really good jd a few months back and ive kicked myself a hundred times for not buying it. If you decide to go with a moldboard plow,in my experience ,on my place,i have to disc,plow and then disc again.A disc plow crumbles up the soil well enough i can get by without the first discing.
Make or model of plow any good brand 3 point will work just fine. As for a baler at best a N series tractor is really to small to handle one well. Ya they can and have done many a bale but it is both hard on the tractor and the person on the tractor. I don't even use my 841 Ford for baling any more due to being a small light tractor and the way a baler works makes a small tractor like a bucking horse and you feel it after an hour or 3
I have Dearborn implements. I am using a 2N. Disc is 7 ft wide, 4 gang, 6 disc's per gang. Plow is 2 bottom, 12 inch shares if I remember correctly. I disc'd 12 acres of corn stubble and it took me a full day for one pass.
