I'm looking at a relay Schneider Electric #92S11D22D-12D
It has a 12 volt DC coil and the contacts are rated "Contact Amp Rating (Resistive): 30A @ 277VAC (NO), 3A @ 277VAC (NC)
It's a DPDT relay.
Whats the 3A VAC (NC) ?
I'm wanting to run an AC unit and an electric heat unit on the same circuit, both 120 volts.
I need the relay to control the heater and using the DT part will insure that both can not run at the same time.
This is for out motor home.
Thanks,
Dusty
It's a DPDT relay.
Thanks,
Dusty
