remote 12 volt testing
JimS
How can someone test an automotive item remotely without lugging a 12 volt battery?
I would like to test the trailer brakes on a trailer. It is an old trailer that currently does not have the emergency battery hookup on it (It will when rebuilt.). I also do not want to test using the wire hookup to a truck (I think the wires are damaged.). I would like to apply power as close to the brake actuator as possible to verify its function and rule out any other faults. The trailer is to be rewired anyway, so cutting the wires to test is not a problem.
Someone suggested that I use a portable jumpstart unit. Simply hook the jumper cables to the wires in some manner, tun on the jumper unit, and see if it works. My concern with the jumper unit probably supplies more amperage that the actuator was designed to handle. Am I correct? Would this be a problem? What else might I do to test this or anything else remotely?
If you jack up the axle and spin the wheel to make sure it isn't frozen, cut the brake wires at the wheel's backing plate, then strip about 1/2 inch. Hook up the Jump Start pack with a good ground!!, and position your self so you can touch the cut wire while rotating the tire. The brake will not take excess power from the pack. I would just make sure the wheel responds to the electricity. If it works, there is no need to keep it hooked up for more than 3 or 4 seconds. No issue. Jim
Just about anything that will provide DC voltage, a jump pack will work, a small battery like what's in a kid toy car, even a power tool battery.
You'll have to get the wheel off the ground though to see if the brake works though, just because the magnet coil will draw a spark doesn't mean the brake is actually working.
I assume the trailer is empty, so unless it's s really heavy trailer or a very light tow vehicle, just to get it moved, will it really need brakes? I would be more concerned with tire condition and wheel bearings.
Connect any battery to brakes.
My dump trailer used the 12v battery that is used to dump load.
While driving on grass, pull the brakeway cable and all 4 wheels should lock up and slide on the grass.
If the trailer has been setting for some time, the drums might be so rusty that the working magnet will not be able to prove itself.
Might have to drag the trailer around until the magnet scraps the rust off the drum sufficiently.
A 12 Volt DC jump pack should work fine for that as its basically just a 12 volt battery.
You asked . My concern with the jumper unit probably supplies more amperage that the actuator was designed to handle. Am I correct?
The jump pack probably has less energy than a good strong automotive battery so I dont see that as a problem for light duty testing purposes.
Subject to the brake controller all they do is supply regulated/controlled DC to the elec brake magnets and if you hook them direct to say a battery or 12 volt jump pack that will simply yield full power. I liked to set my brakes and controller so with an empty trailer if max was applied using the electric brake controller the wheels would skid and of course with a load there would still be braking but maybe not enough to lock the wheels completely
If you jack up the trailer so the wheels are free to spin and with them spinning apply DC direct to the magnets you will see if they are working. With full unregulated 12 volts applied and basically no load on the wheels Id expect them to stop turning INSTANTLY if all else is okay
The brake magnets are simply electromagnets and as current is increased so is the magnetic field therefore more braking. NOTE of course they (brake magnets) are only a coil/winding of wire SO THERE MUST BE CONTINUITY for them to work which an ohm meter or continuity checker will confirm.
NO I dont think flashlight batteries (enough in series to get 12 volts) can provide enough energy to make the brakes work very good because the load is too great (requires too much current) and the battery voltage will drop drastically. They just dont have enough energy to operate elec brakes even if sure enough can add up to 12 volts. However sure they could be used for continuity and voltage checks and checking wiring and connections under VERY SMALL LOAD VERY LOW CURRENT DRAW testing but NOTTTTTTTTTTTTTTT for any good brake testing.
Jack it up, spin the wheels, apply 12 volts to the magnets SEE IF THE BRAKES WORK
NOTE one big problem I always found was BAD LOOSE WEAK OR RESISITVE GROUNDS grrrrrrrrrrr You gotta have good solid grounds and good wiring connections to each brake
NOTE those cheap non solder crimp n pinch connections going bad can cause brake failure BIG TIME......
INSURE GOOD GROUNDS AND ALLLLLLLLLLLL WIRING CONNECTIONS
John T
JimS,
The jump pack will do. Put the negative clamp on the brake motor ground, and just touch the
Plus side quickly. It should tell you if it's working.
The shores will move if they are free,
Guido.
2 long wires connected to the battery on a vehicle run under the trailer would tell you for each wheel the wires could be switched from wheel to wheel for the test.
