remote hydaulics
bosn
I need alittle help tyring to install remote hydraulics. I think I have the needed parts just can"t figure out where to run the hoses from, to the controls. I was hoping when I ordered the remote valve it would have some type of drawing. I have the manuals but no help. The tractor is a Shibaura (ford 1500 is the same/shibaura made it for ford). Just alittle direction should get me going I hope.
bosn
The remotes talked about on here for the 600 800 etc series fords are dual and single valves that mount under the seat. no hoses to them, just hoses off of them. For what I can figure out from your post you need to come off the pressure side of the pump to the valve and return to the resivor. Can you post pictures or give more info?
The Ford 1500 had a remote valve that bolted to the side of the Hydraulic cover under the seat with hoses that ran to the rear of the tractor to plug into for what you are going to run. When the 1510 came out they had a remote valve with metal pipes running back to plug into. The two spool loader valve for the 1500 was supplied oil from the hydraulic block via hoses.
Mark
