remote hydraulic
LC
I"m looking for someone with experience with a remote hydraulic valve for a Massey 1959 TO30. It is located under and to the right of the drivers seat. The valve lever seems frozen, but before I take it apart to see what I need to do to fix it, I wondered if there would be something else I could try. Can anyone help me?
Thanks.
Oops! It's a TO35. I recently bought this tractor and am not familiar with its operation. I put oil around the lever area two weeks ago and when I got on it today, the lever was not frozen. I found out that the lever must be in a certain position to make the 3 point work. Now I want to be able to make the remote work, so I can use the hydraulic ram on a disc and a rollerharrow. Can someone help me?
Is it a selector valve? and does your tractor have 2 quick couplers for a remote cylinder. I'm more familiar with the newer hydraulics on the 100 series tractors but someone on here will be able to help you. You can't use the 3 pt. at the same time as the remote hydraulics. Dave
If its like my 135, the latched lever has three positions. Three point up (and controlled by the orginal controls that control the pump), three point locked and remote functioning, or three point down. Use google to find mf130-180aux-hydraulics.pdf which is the factory manual on the later remote valves. It explains the operation well.
Gerald J.
