The track adjusters on my JD350 are almost fully extended, to the point that they buckle upward at the point where the piston emerges from the cylinder.
There is about 1.5" of rail in front of the idler axle bracket.
After I pump up the track adjusters, I can only run for a short time before the packing gives way and the grease escapes from the back side of the cylinder (where the piston enters)
I've read somewhere that I could remove a link to shorten the chain, thereby allowing the piston to be about 3" farther into the cylinder.
Is that a viable option? If not, what other recommendations are there?
