Anonymous-0
I have seen a lot of different ways to remove broken bolts on this sight, most of them in castiron heads, or blocks. Today I used a cutting torch to remove four broken bolts on a Ford v8 head used to attach the exhaust manifold. This really works good. The cast iron is not cut at all, just the iron bolt is removed. Then run a tap through the hole. These bolts were not in bling holes, which made it a good clean cut. Blind holes will be a little harder, as the slag will come back at the torch head. You want to get in and out as quick as possible, to keep from heating too much. Does any one else use a cutting torch for this? Wroks for me. Stan
