Removing PTO shaft on a drum mower
Anonymous-0
The power of liquid wrench...............
And a little coaxing from a partner w/ hammer and drive pin while I compressed the flange. I's a trusting sole :roll:
After a few days of tapping and squirting, I got some free movement today, Old guy that has been coaching me thru the haymaking bumped it a little and everything is off.
Now the problem.... Yoke is distorted some and one hole seems to be a little eggshaped. New PTO here is expensive here. Is there a reasonable to cheap source in the States to get a shaft w/ overrunning clutch) ? Compressed length is about 28 inches.
Thanks, Dave
I think whole pto's are pretty spendy here too.
Can you replace just the yoke/ knuckle?
--->Paul
It's hard for Joe Blow to find individual parts like that here. By the time I pay the shop, might as well get the assembly. Prolly get a ujoint and see if I can get it in place. Maybe a little selective tapping. Also check ebay for a used shaft. I saw a site in the Styates for parts and had a picture of what I need, but couldn't figure out how to order from them.
Dave
(quoted from post at 14:22:44 07/02/10) heres some from surplus center.They don't have clutch on them but you can add it on.
LOU
Untitled URL Link
Thanks Lou! Got some play time now (mowing is done and the dry/hot weather doesn't promise a second cut this year) so I'm experimenting. Ordered a PTO overrunning clutch adapter from Yanmar Tractor Parts for 75 bucks including shipping. Hoping it'll let me use a normal PTO shaft that'll cost me 55 bucks (as apposed to 400+ for one with built in ORC).
We'll see.
Dave
I believe I'd work on my distorted yoke and egg-shaped hole; a vise and hammer can do wonders, even without a torch.
You also might want to try Agrisupply.com. They have all the latest Chinese drive shafts, might even have one with the ORC.
C&C Mach. in Johnson City,Tenn has a drive shaft with an OR clutch. http://www.ccmachinery.com/pto_shaft.htm
Series 5
35.00"
48.00"
1-3/8’ Z6-Twist collar
1-3/8 Z6-QD Overrun Clutch
AC52917$ 175
6-9 Disc-8'- 10.5' mower Series 6 39" 52"
EG62917 $ 185
