I am working on a Ford NAA. I needed to remove the front tires from the rims. Every thing was in good shape except there were chuncks of rust on part of one tube.
Should I be concerned about this ? The tubes have held air for several years.
Would it be a good idea to clean these particals off the inner tube ? I am concerned about causing leaks when removing the rust.
If it is good ide, what is the best way to remove the chucks of rust ?
Many thanks for any help you can give me.
Thank You
Thank You
