When I rebuilt my "37 B, one of the things I did was replace the damaged main case. I would like to remove the original serial number tag from the old case and reattach it to the new case.
Do any of you good folks have a way to remove the old rivets? I have tried to grab hold and twist out with a vice grip with no luck. I"m sure I could knock the heads off with a chisel, which will work fine for the old case, but on the new case, I would like to put the tag back in the same location. I don"t think I could drill the broken rivets out, because they are hardened.
Any thoughts?
Thanks,
Kurt
Any thoughts?
Thanks,
Kurt
