Removing spark plugs
Animal
I was working on a 620 John Deere yesterday and had to remove the plugs, those 2 buggers took a half a day to get out! I worked and worked and sprayed kroil on them and worked some more. Do any of you have a better way? If so what is it.
If not taking out and cleaned up every now and then they sure can be a animal to get out. BTDT. Are you sure they are the right ones? Heat.
Now that would be a fight. Understandable. Lucky you didn't snap them or something else. Just have to cuss at it and go for a walk then come back to it. Patience and Pblaster.
Hi
Just wondering if a little anti-sieze on those plug before you put then back in would help any.Might have to be some that will take that kind of heat
Every Time I replace Spark Plugs, I put a little "Dab" of Silicone Grease on the Top of the Threads... Granted it will Disipate to some degree ,But it will leave a Film on the Threads, Never had a problem with Cast Iron heads Or aluminum... Larry KF4LKU
Permatex Molybdenum disulfide anti-seize is great. Aircraft mechanics have used mica based anti-seize as well. The heat transfer capacity is important, I would be sure the material I use was not a barrier. JimN
Copper anti-seaze is made for higher temps. I use it on just about everything, espescially spark plugs and anything that gets hot, like exhaust manifolds and muffler clamps.
Donovan from Wisconsin
Hard to believe you had trouble getting plugs out of a 2 cyl. ? I have torn some nasty rusted ones down and haven't encountered that yet.
