Mad Farmer
- Location
- Northeast
Hi folks.
I thought I was just going to have to replace the blades and the bolt assys that hold them.
I got under it to look over things and the bolts are actually loose in the flywheel/stumpjumper. I don't think the nuts worked loose as they have been on since purchase ~1990. Looking through access hole the nuts don't seem to have backed off the bolts.
Is this a common problem/occurance? It just started making noise from tapping the deck a bit last summer and I figured I'd bent a blade or the pivot on the bolts/blades were worn out.
I'm a little concerned now the flywheel/stumpjumper may be damaged too. That is the bolt holes wollered out.
I'll know for sure when I have time to pull things apart. I'm assuming I'll have to torch the bolts off as they are probably going to spin. I can do that if needed
Would it be worth seeing if they'd tighten up first? I have my doubts as to that as they are pretty floppy right now. What are chances flywheel/stumpjumper is shot?
Next question. If I have to pull off the flywheel/stumpjumper how much of a PITA is that and do you need some sort of puller? It's been on there 30 years. Part is still available.
If I have that off worth replacing the seal? Have had no leaks all these years.
