replacement blades for wheelhorse commando 6
histoman
Have a Wheelhorse commando6 with a 32 inch deck. I have been looking without success for the blades for it. Any suggestions? Each blade had a center hole with smaller holes on either side of it that fit over pins in the shaft that the blade bolts onto. Thanks for any info.
If you haven't done so already,check with local toro dealer,if he can't get for you,if you have pn for blade(s) or don't know pn for blade,measure length of blade,goto ebay & search item# 110785162151 and see if these blades will work for you,if they won't work & you have pn for blade do a goggle search for wheel horse+pn see if anything comes up,you have the old style blade hub same as I have on my charger & raider tractors,this style blade is getting hard to come by.
Its a real help with Toro parts if you know the deck model #.
A dealer can go online and find out what deck was sold with the tractor, with the tractor model number. (The number on the tag under the seat. Not the number on the hood.)
The thing is, lots of those decks have been swapped out over the last 20 years or so, mainly due to rust, and some tractors don't have the deck under them they came with.
