replacing coil
Anonymous-0
I have a 52 model 8n 6 volt,positive ground with side mount dist. The coil I removed had terminals market "batt" and "dist", but the replacment coil is marked with only "plus" and "minus" signs. Given the system is positive ground I"m not sure which wire goes on which terminal on the new coil. Please help
Simple: The coil is grounded through the distributor points. Positive ground, plus goes to the distributor. Negative ground, minus goes to the distributor.
I think I fixed it for you. Simple: The coil is grounded through the distributor points. Positive ground, plus, goes to the distributor. Negative hot, minus, goes to the resister.
The primary wire from the coil to the distributor ALWAYS has the same sign at the electrical system ground.
