Hi All,
I'm working on replacing a seal in the left drop box on my Ford/New Holland 1720, manufactured in 1987. I have the manual, the
tools and a good mechanical aptitude, but little experience working on a tractor so am seeking some input and advice here.
Following the procedure in my manual, I'm stuck on removing the wheel hub case from the lower assembly. It appears to have had
some type of liquid gasket applied to the machined faces before it was painted in the factory. I've tried using a piece of wood
and a hammer to loosen it with no effect and am at a place where I see two options to separate these cases.
1. Using a wire wheel, or sanding disc to remove the paint at the joint between the two cast parts and trying to get a knife
edge in at the seam to separate them
2. Grind the edge of a chisel flat to remove the cutting edge, then placing the flat edge against a spot where the hub case
protrudes about 1/32 outside of the dropbox case then hitting that with a hammer to break them open. My worst nightmare would
be breaking one or both cases with this method.
Does anyone here have experience on how to safely split cases that are stuck together like this? The seal that needs to be
replaced is marked #3 in the attached image figure 17 and the stuck case cover is #2 in figure #15.
Thanks in advance for any thoughts on this.
