Rhythmic bumps while moving
2023 L4060 200 hrs hydrostatic 4wd w/loader.
Recently developed a ‘rhythmic bump’ while driving. At first I thought it was the normal tire vibration you get with R4’s on pavement. It has been dry here and the clay is like brick. We got some rain, the soil is softer, and I still am getting it.
It becomes noticeable about 1.7mph, really sets in about 2.3 mph, and is there up to 3mph which is about as fast as I ever go. I feel it worse in the steering wheel but can feel it thru the seat. It is speed related as it is roughly the same in low or medium range. Haven’t checked 4wd but suspect it won’t matter, I use 4wd very rarely.
I try not to over stress the loader, and I don’t drive fast or far with heavy loads. As you can see by the hours it does not get a lot of use, and most is mowing or loader work well within its capacity. I have on 3 occasions tried to pick up something buried too deep (cleaning up old equipment graveyard) but quit after 1-2 tries.
Any ideas?
At this point my next diagnostic would be to mark the tires and try to isolate it font to back, and maybe side to side based on wheel speed, if it tracks.
Flat spotting from sitting? More likely a tire going bad, belts or cords have split, resulting in a bulge in the tire.
Ben
Frequency seems higher than a flat spot would be. But a couple of good things to look at.
Please, please don’t let it be a rear axle bearing….
Tires are beet juice loaded but only going 2-3 mph.
Certain it’s not in 4wd. I will see if it is still there in 4wd.
Good suggestions and I will do more analysis when I get it out again.
All lugs and rim fasteners to torque. It is there left/ right turning as well as straight. The frequency is faster than wheel rotating speed, if it was a truck I would be thinking driveshaft or pinion. I’ll have to look at a diagram, if brakes are on a bull pinion that could be an option. More testing once it stops raining lol.
