Rigid 9" Angle Grinder Opinions
big a
I need a new one, and don't want to spend new price! Been accused of being a tightwad more than once.
Been perusing pawnshops lately and found a Rigid in as new (looks to be unused) for $60. Probably buy it, but thought I'd ask opinions first. I have a Rigid cordless drill I have been very happy with, but that doesn't mean much.
Andy
Probably get trashed for this but a question you need to answer in your own mind is in reality how much are you going to use it? I always have a couple 4 grinders around that see 95% of the usage because they are lighter and handier to use, currently they are both Makitas. I also own a 7/9" Milwaulkee purchased new 10 years ago that will likely be fought over by my estate unless I run over it or the shop burns down because the reality is it sees very little usage. I would be just as well served by a cheaper unit. If your only going to own one grinder buy a good one otherwise the Ridged will likely serve you well no more than it wil be used.
Husband uses his 4 inch angle grinder way more often than his big one. Same as you said... just more compact and lighter to work with.
I agree with Butch I have an old 9" Craftsman hardly been used. Also have a 4" metabo with a slide switch and a milwaukee with a paddle switch.
Don't ever buy a slide switch if the cutoff wheel catches and stops turning it'll burn up before you get it turned off. Also had a 4" Porter Cable that lasted 14 years.
I bought a really nice 7" Makita at a farm auction. Think I paid maybe $20 for it. Used it one time and that was enough for me. Sold it on Ebay and went back to using my 4".
As an 'only' grinder.... No. I'd pass on that. As a heavy grinder ofr cutoff wheel work or heavy grinding... go for it. I've got a 4.5" MasterCraft, 5" DeWalt and 7" Hitachi. Of the smaller two I prefer the yellow one. For serious grinding... I put a heavy wheel on the 'tachi and get some work done.
I don't use the 7" much these days but it's always here.
The problem with a 7" or 9" grinder is that they are HEAVY for everyday work and the head and body are too large to get into a lot of spaces for intricate work... hence I keep a couple small ones for that.
Rod
I have a big "saxaphone" air grinder. I haven't used it in years. To use something like that, you really need a face shield + safety glasses, safety shoes, and some sort of chest protection. A wheel that big lets go, it can really hurt ya.
A very dangerous oversized tool for most jobs. One ripped my hand open even with gloves on in 1967 when it kicked back on the piece I was grinding. These units need a shoulder harness and a safety switch arrangement. I haven't used it but about twice since then. keep a 4-1/2 one always now. Lighter, faster and safer to deal with if it grabs.
Find a name brand 5 or 6 inch grinder at least 10
amps. and it will do 95% of anything you need. A
7"/9" is only needed for really heavy grinding jobs
and will wear you out. A 4" will burn out in no
time. A 4 1/2" around 6 amps is good for lighter
grinding or in small spaces.
Snow plow builder had a bunch of slide switch 4 in grinders.Fellow squatted down grinding , d ropped the grinder.It bounced off the floor and cur a groove in his cheek.Boss busted up the grinders and bought new ones with a paddle switch.Useful tools but dangerous to use.
I've got a big milwaukee that I got out of a dumpster 15 or so years ago.... Only time I used it was cutting cobblestones (a bunch of them) when we did our driveway 12 years ago... Have several 4" ones that get used.. So many because I never can find one when I need it and they cost 8 or 9 bucks with a store 3 miles away :roll:
Don't even really know where the big one is right now.......
Pretty well have the 41/2" grinder area covered. 2 Milwaukee's and a Ryobi dedicated to a wire brush. I do enough metal work to often want something larger. Also, I was mistaken....what I want, and am looking at is a 7"...I'd agree 9" is too big for most stuff.
For the price...less than 1/2 of new, I think I'll snag onto this one.
Well....change of plans! Went back today and, of course, it was gone! On the way home stopped at a garage sale and found 2, a Ridgid like I was looking at, and a like new Makita. Got both of them for $35!Figured for that price, I could put a cup brush on one and just leave it.
Sometimes things just have a way of working out, maybe even for the better!
