NO!The Jd rims are 'double bevel',the M wheels are 'drop center'.However,if you use 450/560 wheels they will fit the JD/double bevel rims.
(quoted from post at 15:49:50 09/02/12) NO!The Jd rims are 'double bevel',the M wheels are 'drop center'.However,if you use 450/560 wheels they will fit the JD/double bevel rims.
That is not true. Only the late JD rims will not fit. JD switched around the same time Farmalls switched from deep drop to double bevel.
