javan
Is there any tricks to putting on a new ring gear? I took the old one of ( IH cub) and found out it is hard to put on the new one
Use a torch to wasm it up and it will slip on easy. I fasten a pair of vice grips and then go around and around with the heat source till it will slip rite on.
Money well spend to pay a PRO to do it, may be he will let ya watch.
Flywheel ring gear install
You can also just set it on the flywheel and heat it there. gear will heat much faster than the flywheel and eventually drop on. Have a hammer and driving punch handy to make sure it seats. just go around the gear with a torch, preferably a rosebud tip.
jt
