Road trip pictures
grandpa Love
Well.....it was on a trailer headed to the scrap yard! Not terrible. Can't get it in to any gear. At least it wasn't stuck in gear. No exhaust pipe....u can see water in the manifold. Maybe a good parts tractor.
I used that lift set up to make a 3 point hitch on the C I have and it works pretty well. Plus that one has a hyd pump so you can add hyds to your B. But you told me your wife said NO more
Has all the parts you need to convert yours to electric start...including the flywheel with a ring gear. Also the hyd pump and valve is a bonus. Sure wishI had the lift assembly bolted on the the fender braces. Good buy for you!
Just read where this tractor was the number 1 sought after tractor for use in sugar cane farming when tractors began to replace the mule in the field.
