WeirdDeere
Rockshaft/3 point issues on a 60. Drifting down quickly, spongey as well.
JUST got a 3 point on my 60. It's been setup with a 45 loader for as long as I've known the tractor. I know that I can't separate the loader and rockshaft functions, I'm working on getting a Baker Valve on to solve that.
Right now, with the proper plug adjustment, I can raise and lower the rockshaft just fine, but the 3 point drifts down fairly quickly even with no weight on it, and if I stand on it it drops even faster. When I do stand on it, it seems spongey, it drops, and when I get off, it springs up slightly.
I have cycled the rockshaft up and down 10 times or so, I don't believe it's air in the system. The loader has worked for years under this setup, it stays up with no problem. (though I did notice up on the loader is down on the 3 point, and vice versa). I have an adjustable plug in the top port.
I stupidly thought that since the loader worked just fine that the rockshaft would work just as well since it's basically the same hydraulic circuit, but I'd love to know what I'm missing.
Thanks,
Brandon
