Crashfarmer
The 3 point hitch on the 8N I bought on the 28th of September was stuck in the up position. I was using my H Farmall today and got to thinking that since the H has 2 way hydraulics on it the Stanhoist loader has down pressure. So, thought it was worth a try. Pressed down on the 3 point and it went down immediately.
I backed the H up,shut it off, and started the 8N. Raised the 3 point, stuck up again.
I started the H, moved it into position, lowered the loader, 3 point went down again.
Shut the H off and just left it with the John Deere snow bucket on top of the Ford's 3 point hitch.
I raised and lowered the 3 point several times with the loader on top of the 3 point. By the time the 2 tractors worked themselves apart, the hitch went up and down flawlessly.
I assume that some little speck of rust or debris accumulated in the wrong spot and caused the problem.
Solved, stuck up 3 point problem.
