Anonymous-0
Anybody ever put a roll tarp on a throw rack?
I'm wondering if I could store hay like this for a month at a time give or take.
My thought is pull up to the guy's barn I buy my hay from. He could throw it down and I'd stack it on the rack. Pull it home, park it by my barn, roll the tarp to cover it up, and feed off of it.
Would I need something on the sides? I'm in northeast Iowa.
WF
I've stacked it on the ground in roughly wagon sized stacks. Covered with a plastic tarp. Wasn't pretty. Bottom layer spoilage, keeping tarp on pile, accessing hay under tarp, all problems. Wind damaged tarps too. Unless rain always falls straight down, you need to cover sides. I did store a wagon load of bundled oats under a new plastic tarp. Was able to secure tarp pretty much fully over load and around sides. Since load was shaped like a loaf of bread, and tarp was well secured, it held pretty well, kept the rain off pretty well. Baled hay may not shed water as well, unless you park on a sidehill!
i don't see why it won't work. a few nylon cynch straps on the sides and a couple in front should hold it down. keeping the tarp tight will help prevent pooling.
tarp on the sides might be worse than no sides moisture-wise and would be that much more tarp to mess with. sounds like a good project.jim
I did that a couple times it worked out all right. the ends got wet on mine since my tarp wasnt big enough. i stacked bales on it to hold it down so the wind wouldnt take it. it was a homemade roll tarp of sorts too. got a blue plastic tarp from the fleet store and bolted it through the metal holes in the tarp to a peice of plastic pipe. put a extra foot of pipe out one end with a half inch hole and ready rod bolted through it for a t-handle of sorts. use it now to seperate part of the shop to make it easier to heat.
