Roloff weights
Lynn Patrick
Any hints on getting the wedges on Roloff weights loose? It's a Hat rim that I will take the tire off & see if it's worth saving, but the weight wedges are rusted TIGHT! Bolts are also rusted in place. Thinking maybe take the whole thing off, lay it down weight down, & beat around the center disc w/a REALLY big hammer??? Other thought PLEASE!!
Heat, as in a torch, will usually do the trick to losen used bolts & nuts. But be careful! You might want to dismount the tires first or at least deflated them.
A mixture of ATF and acetone should loosen the rust.
Be careful getting the wedges loose, they will break. I think they are cast iron and I couldn't find them any place.
I've gotten them loose with a 3 day program ofL
1. Gibbs penetrating oil on day one and a rubber mallett tapping on them with a round piece of oak fire wood.
2. 50/50 Mix of Automatic transmission fluid and acetone on day two, repeat rubber mallet and roudn pieve of oak fire wood.
3 Day 3, Gidbb penetrating oil, rubber mallett with oak fire wood and then move to a small machinist hammer and the oak fire wood, then a small punch.
They didn't rust in a day and sometimes we get impatient and think the need to come unstuck TODAY. Time is your friend
Don't beat or reef on them.
They are soft cast iron and break rather easily.
