rotor cracking
(quoted from post at 20:36:50 10/11/10) the rotor in the 9n is catching on the cap posts and cracking anything specificaly to look for? thanks
e sure the rotor is firmly pused down in place, get a "good" rotor from NAPA, check the distributor bushings for play. I had the same problem with china made parts:
Gust,Cheap almost correct Chinese junk parts.Get one more and grind 1/32nd to 1/16th if a inch off the tip so it will clear the cap terminals.
Compare the new and old rotor with dial calipers before putting new one in.Old parts are always better quality.Tune ups are a feel good operation most of the time anyway.
(quoted from post at 05:22:16 10/12/10) Compare the new and old rotor with dial calipers before putting new one in.Old parts are always better quality.Tune ups are a feel good operation most of the time anyway.
I agree
During a "tune-up"
if your old cap and rotor are working well together,
clean them up and put them back on.(don't forget to use some fine steel wool and a screwdriver to clean inside the SP wire posts)
New parts are getting so bad, I've been talking to some local
dealerships/shops about leaving a bucket there, and when they
do a tune-up, throw the old parts in the bucket for me.
This same thing happened to me with Napa parts,re-bushed dist,re-aligned top and bottom bushing[carefully,but still a pita].Runs much better,points were still good after 4-5yrs,but still put new ones in,kept old ones in "bone box".---lha
