MarkB_MI
- Location
- Motown USA
Shouldn't it be possible to make the leveling box link shorter than the fixed link on the other side? My fixed link is about 29 inches from pin to pin, but I can only shorten my leveling box link to about 30. Once I screw it in that far the screw just spins without getting any shorter. Also, there's a groove in the screw shaft that I've always assumed marks the adjustment midpoint, but I can only get the lower link to within about 3/4 inch of that mark. So I assume the threads are trashed and I need a new leveling box assembly.
My tractor is a row crop four cylinder 4000, basically a 961. What have y'all used for replacement leveling boxes on your row crops? I'm doubtful I can find a serviceable one from a scrapyard. YT/ASAP sells a "901 Leveling Box Assembly", P/N HLBMF62, but it lists that same part number as being applicable to the non-row crop models. Also, they say it fits the 4000 EXCEPT row crop! My assumption is this doesn't actually fit the row crop tractors. Unfortunately no specs are given for this part.
I came across this post which says a leveling box assembly from one of the three-cylinder 4000 tractors will work, but there are no specifics. Has anyone tried a three-cylinder leveling box? What did you use and how did it work?
