RUNNING BUT NOT WELL
JIM603
First thing first thanks to all with the posting from 7/11. Still no spark got her going today, now my problem is this. She backfires threw the carb when pulling a hill no attachments just tractor.and now the starter ingages when it feels like it key turned off and tractor running or not.I forgot to tell you all what I have, 1950 8n side dis. 6 volt pos. ground. Need to know how I can fix. Thanks for the help.
If you have an OEM wiring set up, the ignition key should have nothing whatsoever to do w/ the starter engaging.
Sounds like the thumb switch or its wire is grounding causing it to engage. Check both.
You got an extensive amount of information from a number of folks who responded to your previous post. Rather than repeat ourselves, what you have done to the tractor lately?
The latest problem sounds like points & timing issues. Did you replace the points & set the timing?
50 Tips
No Bruce did not replace the points but did try to set the timing, not sure i got it right. When by my I&T book to set the timing and thats how i got her started. But like i said she backfires throw the carb. Its this timing or points i would guess to say timing. Also found today that my cap looks like it is wobbling on the dis. Like my roder is pushing on it. Made sure roder was on right it is. May be that made in Mexico crap.
" Its this timing or points i would guess to say timing"
It could be either one.
And if the rotor is touching the cap (look at the cap to see if its touching) then you have another problem.
Time to start over.
First, replace the plugs. If you flooded it, they're fouled & it will be it next to impossible to start. You don't need to toss them; heat the tips for a few seconds w/ a propane torch to burn off the invisible spark-robbing deposits from today's additive filled gasoline........or wash them in lacquer thinner.
Get a new cap and rotor from the same source. (no TSC junk)
Check the points, dress them & verify the gap at .025. If they are burned or pitted, or you can't get the .025 gap, replace them.
Make sure the firing order is correct: 1-2-4-3, CCW.
In order to get max current to the ignition system, make sure the battery is fully charged (or jump it; see tip # 43)
Then, use propane or starting fluid.
If it still pops & backfires, post back for more info on static timing it.
50 Tips
I think,like Bruce said,get some GOOD parts,like from Napa.However,I have gotten rotor&cap from Napa,and broke off the rotor,difference is Napa replaced it,others might not.I fixed mine with a small piece of duct tape folded sticky side out,put on shaft,carefully put on rotor,no prob.---lha
