With it being winter, I have a little more time to think about some more abstract project ideas (my mind wanders while I am shoveling manure or splitting wood)...Lately I have been thinking about the old John Deere all fuel tractors that would, when up to temperature, burn "stove top fuels".
My question is, keeping in mind I probably will not undertake this project anytime soon (especially while gasoline is RELATIVELY cheap) what alterations would be necessary to make say a JD 60 or 70 gasoline model burn cheap mixtures of fuel, say 50-50 gas and used cooking oil?
My understanding is that up till about 1947 all JDs would have been considered "all fuel" and that the company continued to build all fuel models for some time with the greatest difference btwn models being a hot manifold, lower compression pistons, slightly different carburetor, and different spark plugs.
And while a few all fuel early numbered series tractors remain in existence they tend to be more pricey, i.e. the last all fuel 70 I saw on craigslist was $7000+ (Pennsylvania).
Now I wonder whether a gasoline model 60 or 70, or other comparable model, might be made to burn low cost fuels with a few non-permanent alterations. Such alterations might include:
1) Hot manifold OR setting the heat exchange valve for cold weather operation to preheat the heavy fuel as it is drawn into the engine.
2)Use of a higher range thermostat, say one that begins to open at 180 and is fully open at about 200.
3) Addition of an auxilary gasoline only fuel tank connected to carburetor, AND insertion of fuel shut off valves between both fuel tanks and sediment bowl/carburetor.
4)Use of spark plugs recommended for all fuel operation.
5)Keeping crankcase oil level about a quart extra full and periodically draining off excess through test cock to compensate for the dilution that heavy fuel use causes.
6)Lower compression pistons? (Not sure if any still are in manufacture or whether it would be wholy necessary since a 60 year old tractor is bound to be lower in compression now than when it left the factory unless it has been reconditioned recently.
Let me know your thoughts or if anyone has attempted this. Not trying to waste anyone's time here but curious about the idea of running the old JDs on cheap fuel since I am not nearly old enough to remember a time that gas was under $1 per gallon. And while I realize that waste oil blends probably lend themselves to diesel engine applications more readily I would rather fool around with a $2000 JD 60 than a $10000 4020 where the consequence of messing up an engine is far more costly.
Thanks,
Pete
Thanks,
Pete
