Running Rough when hot.
toolman716
I have an MF 202 Industrial and when it is warm out, about 75-80°, and I'm running under load, it seems to be losing power and the tractor runs rough. I just tuned it up with new points, rotor, cap, wires, and plugs, but I was wondering could this be a carb problem or the coil? It seems to run OK after it has cooled off again.
Mike
if your problem started after the tune up try replacing the condensor with the old one sometimes you can get a bad one also i have seen one act like it was runing lean on fuel under load the mechanic changed a new set of points to another brand solving the problem doesnt sound reasonable but it worked
I had the same problem with my 135 and as soon as I replaced the coil it went away. It would start misfiring and acted like it was running out of gas, but as soon as it cooled off it would run fine.
Changed the coil, voltage regulator, points, and condenser. No real change until I adjusted the carb. I have a Continental Z134. I made a couple of adjustments turning out the Main Fuel mixture screw. The backfiring has stopped and it seems to be running a little better, but it still is lacking power. Any ideas???
