Russian roulette with a log splitter
My neighbors hydraulic splitter is that fast, he has a 4 sided wedge that splits the logs into 4 pieces. It has 5" diameter ram and a log splitter valve that cycles back when you are grabbing another log. 10HP B/s motor too.
In 1 hour I split 2-3 face cords.
Hard to believe that's a rated 37 ton splitter, if a simple chunk of wood can stop it ...
you'd think he would put a simple guard in place for protection of the fingers.
thanks for sharing..
zeke
I have some friends who've been in the firewood business for 50 yrs., and have had many splitters- one was mechanical, and fun to watch, having one throw of an old Chrysler crankshaft connected to a Pittman-type arm, a couple pieces of rack gear, and a saw-tooted edge plate, and it, one tooth at a time, punched it's way through the round- lift the arm of the side plate, and the sliding base unit would gravity return to the bottom- worked pretty sweet.
Then they built the vertical air-powered one...
that f*#cker came down so fast and hard, it blew the two halves of the round about 30' in two directions, and put a 1/4" groove in the baseplate- took about 15 minutes to cut the whole thing up with the torch
Now thats the one I like!
Probably a little over production for what I use however. Apperently the saw was run off hydraulics with the ram - Hmmm, interesting and a lot safer the original post IMHO
You guys see a va series ofset tractor on tractor photos for sale in Seven valleys pa. Didnt know there was any.
Indeed. Leave the beer in the fridge...
I'll give it one thing tho. It's a bunch safer than the baler unit shown the other day. That was DANGEROUS. Even for me.
This... I can see using. There's a way about it that would work.
Rod
